If your RPM's are low, the very first thing to check is barnacles or a fouled prop. This is fast and cheap. Just need a snorkle and a paint scraper. If that doesn't cure your problem pull the riser ("U-shaped) on the top of the exhaust manifold. They 'carbon-up' and block the flow of exhaust. Mike
