Steering quadrant / pinion gear adjustment
  • PlumBob
  • PlumBob's Avatar Topic Author
  • Expert Boarder
  • Expert Boarder
3 months 2 weeks ago - 3 months 2 weeks ago #5935 by PlumBob
PlumBob created the topic: Steering quadrant / pinion gear adjustment
In an older post (#2080), VicC stated "There is a steering play adjustment mechanism. It is located over the quadrent and holds the quadrent down onto the pinion gear." www.ipyoa.com/forum/52-bottom-paint-prep/1470-rudder-shim-kit
I would really like to have some written guidance concerning this adjustment. Vic, if you are still around, could you send me a copy of the material you have? Or if someone else has done this, give me a summary of the process, please?
During hurricane Irma, somehow Whimsy's quadrant slipped one tooth (of the pinion) out of alignment. (She was sitting on the bottom of her slip for several hours as Irma blew by.) I want to put this back, so that the rudder is truly amidship when the king spoke of the wheel is straight up. I'm hoping that I can open up this adjustment enough to be able to slip back one tooth.
Thanks in advance.
Last Edit: 3 months 2 weeks ago by PlumBob. Reason: insert link to old post
3 months 2 weeks ago #5939 by IPABill
IPABill replied the topic: Steering quadrant / pinion gear adjustment
Here is the description from the Owner's Manual on adjusting the rack tension against the pinion:
  • PlumBob
  • Expert Boarder
  • Expert Boarder
3 months 1 week ago #5942 by PlumBob
PlumBob replied the topic: Steering quadrant / pinion gear adjustment
Thanks, IPABill. I'll surely take a look at this.
Time to create page: 0.235 seconds
We have 735 guests and one member online
