Hi Art,
You can press one, the other or both. The toilet will evacuate faster than the raw water comes in even if you hold both buttons down. You are trying to limit the input water, this is the whole purpose of using a separate supply. This gives you the ability to put water in the bowl first if the situation dictates. It makes the toilet flush cleaner just like at home.
Not programmable, These are simple monetary on/off buttons. Push the out button and the macerator part runs, you can tell when the bad stuff is gone by the change in sound. Push the in button and the Surflo water pump puts raw water in the head, you can watch it fill, Really simple. I did a cut and paste on Defender catalog for a switch that does the job, ( you only need one because you get one with the SeaEra conversion),
Below is a Defender Catalog cut paste for a pump, and an Amazon cut paste for the SeaEra conversion.
Also, Here is a link to the exploded parts view for the Raritan Sea Era conversion.
www.raritaneng.com/wp-content/uploads/20...215SeaEraExpview.pdf Take a look, you remove assembly #162000W on the last page of the drawing – easy, 4 long machine screws. Then when the motor turns only the extraction and macerator part because the raw water fill pump is gone.
The IP 350 toilet output plumbing stays the same it can be directed into the tank or overboard depending on how the valve is set. Do you have a Macerator installed?
DEFENDER CUT AND PASTEPUSH BUTTON SWITCH:
Cole Hersee Heavy Duty Push-Button Switch with Momentary On
Item # : 204591 Pole / Throw: SPST, Action: OFF - (ON)
Max. Operating Amperage: 10 Amps @ 12 Volt DC, (2) Brass Screw Terminals
Fits Panels up to 3/4" Thick, Gasket-Sealed Case
Model Number: M-485 BP $12.99
RAW WATER SUPPLY PUMP: SHURflo®'s 4128 fresh water pump design was created with a unique over-molded single-piece diaphragm, assuring long life and top performance in all plumbing systems
Designed as the next legendary pump to exceed the expectations of our customers, the 4128 pump is constructed for smooth flow
Multi-fixture Marine fresh water pump installation
This pump may be used for general fresh water transfer
The 4128 fresh water automatic demand pump is quiet, thermally protected and can run dry without damage
Specifications:
Voltage 12 Volts DC
Draw: (Max.) 3.5 Amps
Flow Rate GPM/LPM 2.0 GPM (7.6 LPM)
Shut-Off Pressure 30 PSI (2.0 BAR)
Type: (4) Chamber Diaphragm pump
Ports: 1/2"-14 NPSM-Male
Liquid: 130° F (54° C) Max
Dry-Prime: 6 feet (1.82 M) Run Dry: Yes
Replaces 2901 Pump
Sealed Switch
Sealed Motor
Corrosion Resistant Electro Coated Motor
(4) Independent Chambers
Built-In Check Valve
Co-Molded Diaphragm
Adjustable Switch
Self-Priming up to 6 Feet
Dry Run Capability
Thermally Protected
Ignition Protected, CE
Dimensions: 8.2" x 4.9" x 4.1" (208 x 124 x 104 mm)
$81.99
CUT AND PASTE FROM AMAZON
Sea Era Conversion Kit12vRemote Seawater Intake90° DischargeAn inexpensive way to replace your electric or manual toilet. Save the toilet bowl and seat and replace the lower base.Benefits:Economical electric macerating marine toilet. Sea Water models can be run dry without damaging the pump. Low power consumption and quieter operation for on-board pressurized freshwater models. Heavy-duty marine push button switch is included. Product : RARITAN SEA ERA CONVERSION KIT REMOTE PUMP 0 & 90 DEG 12VDC Manufacturer : RARITAN ENGINEERING Manufacturer Part No : 160LR012 UPC : 085462014390 $489
If you wish to discuss more, give me a call – 937-478-7189
