Corian Countertops in Galley
  • bsenay
  • bsenay's Avatar Topic Author
14 years 11 months ago #913 by bsenay
Corian Countertops in Galley was created by bsenay
Hi all - we are currently located in the Jacksonville, FL, area and would like to find a Corian contractor and would welcome any advice on installing new countertops. Has anyone installed these countertops on an older IP? Many thanks!
14 years 11 months ago #915 by Augydoggy
Replied by Augydoggy on topic Re: Corian Countertops in Galley
We also have this item on our list of upcoming projects for our 2001 420. We plan to change the sink out for a larger single basin and add a different faucet. Also plan to add extra insulation around the refrigerator at that time. Also also plan to get rid of the micro-wave and put in a cabinet of some sort there. We find we just don't use it, wasted space. We saw some nice SS fiddles on one of the new Hunters, food for thought.
We'll be interested to see what you do with yours. Must have pics showing progress and before and after. We'll do the same when our turn comes up.
Tom + Cheri
14 years 11 months ago #940 by Auspicious
Replied by Auspicious on topic Re: Corian Countertops in Galley
I have had Corian counters on my HR since new five years ago. I love them and wouldn't do differently. Some thoughts: DON'T put hot things on the Corian; it will burn - put hot pots in the sink. Nice as it may look to have a molded Corian sink stay with a stainless one unless you don't really cook.
sail fast and eat well, dave
S/V Auspicious
HR 40 #68
14 years 10 months ago - 14 years 10 months ago #987 by ejacks2
Replied by ejacks2 on topic Re: Corian Countertops in Galley
Corian Counter Pictures . We installed new countertops two years ago on our IP38, not Corian but a similar product. We found a local contractor from the St. Marys area recommended by a local tile/marble store. The result was wonderful and we are 95% happy with the job, we wish we had increased the size of the sinks slightly to accomodate larger pans and gone with a taller faucet.
We completely redid the refrigeration going with sealing lids from rparts. The frig lid is inboard, the freezer to outboard. They are flush mounted to that the surface can be used for cutting boards, etc. Also, they open aft so that we do not have to clear the surface above either the frig or freezer to open the other. One needs to plan for something to hold the doors open if using this option. I am still using a stick on the frig but am planning on adding a gas spring on the frig, the freezer door clears the cabinet above so it stays open.
Complexities included of the countertops included the hinges and pulls which must be routed after making a jig. Also, the corian increased the height by 1/2 inch or so. My countertop is seamless under the stairs so I had to cut the stair-top the appropriate amount plus provide for clearance over the fiddles. A good option is to make the one part fiddle under the stairs into three parts. I reinstalled the wood fiddles but corian fiddles look great too.
Rather than tear out the old boxes I added several layers of insulation everywhere then used frp paneling, and epoxied the corners and painted the inside using appliance paint which must be allowed to fully cure before cooling or else it will emit odors for a long time (my wife was so mad until we completely emptied them and heated them for a day). I have two compressors and evaporators for redundancy.
I think color is important. We went with a light neutral colors given the darkness inside already. Speckles can look like dirt too but each to his own.
Ed
Last edit: 14 years 10 months ago by ejacks2. Reason: fix link
14 years 1 week ago - 14 years 1 week ago #1447 by Sailbatical
Replied by Sailbatical on topic Re: Corian Countertops in Galley
Do you have an estimate $$$ of your expenses?
Thanks!
Terri Ivins
Sailbatical
New Smyrna Beach, FL
Last edit: 14 years 1 week ago by Sailbatical.
Time to create page: 0.104 seconds
We have 1401 guests and one member online
