Does anyone know where to source a replacement diesel fuel return hose for a Yanmar 3HM35F on a 1989 Island Packet? It is olive green in color. I can't yet see a spec on the hose but will have to dig deeper. It passes from the tank under the galley next to the seawater cooling water intake for the engine. It appears there is a pinhole leak somewhere in this hose. The hose has a crimped copper connector at the tank side with a fitting that screws onto the tank, so I am hoping to find a replacement hose with a new crimped fitting. Is this something still made or do I have to cut new hose and use pinch stainless clamps? Thanks.
I ordered from great lakes skipper.
greatlakesskipper.com/shields-16-360-014...&utm_content=1045965
GLS stock number 1045965 is a new, in the package, fuel hose from Shields, part number 16-360-0143.
Fuel feed and vent - gas or diesel. Meets USCG fire test. Perfect for alcohol enhanced fuel. For pleasure boats only - inboard or outboard.
Specifications:
Brand: Shields
Part number: 16-360-0143
Length: 10 ft
Inside Diameter: 1/4"
Fire-Acol USCG Typa A1 SAE J1527 ISO
