Banner
....You are not logged in
Welcome, Guest
Username Password: Remember me
  • Page:
  • 1
  • 2
TOPIC: LED Lights
LED Lights 1 year, 7 months ago #1053
  • sbrock
  • OFFLINE
I am wanting to replace my present cabin light bulbs with LED lights and there was quite a discussion going on which appears to no longer be in the forum. So again I have not found any bulbs that work and one reply noted an adapter that was needed. I need more information on that and any other suggestions. Thanks, Stephen
Re: LED Lights 1 year, 7 months ago #1054
  • hayden
  • OFFLINE
  • Moderator
Stephen:
I added the 9 LED lights recommended by Bobby. I added them this spring and they fit right into the existing light fixtures. They are not cheap at $22 each!
Here is a photo album of the install and the details:
ipyoa.com/photos/62-hayden/album?albumid=143
Re: LED Lights 1 year, 7 months ago #1057
  • sbrock
  • OFFLINE
Thanks Hayden. Your photos are really helpful and I appreciate the details. Stephen
Re: LED Lights 1 year, 7 months ago #1058
  • CleoSails
  • OFFLINE
There's an extensive discussion regarding LED lights over on the IP Home Port forum - perhaps this is the one that you were thinking about? Link
Re: LED Lights 1 year, 7 months ago #1059
  • sbrock
  • OFFLINE
Thanks. You are right and I was hunting on the wrong site. I belong to both and simply mixed up which one I was using for this information. The Home Port forum is where I was working on this issue and it a treasure of information. I was in Romania at the time I was posting my first questions and when I got back to the States simply logged into the wrong site. I hope that is just Jet Lag and not an early sign of something else Stephen
Re: LED Lights 1 year, 4 months ago #1211
  • hgk1943
  • OFFLINE
I am looking to add more LED cabin lights to my 380. I am looking for one contact bayonet bulbs. Where can I find them?
Helmut Kramer
Punta Gorda
Re: LED Lights 1 year, 4 months ago #1213
  • hayden
  • OFFLINE
  • Moderator
Use 1142-PCB-xWHP9: White 9HP-LED 1142 PCB Lamp
Select color of Warm White
That is what we used.
Link here:
www.superbrightleds.com/cgi-bin/store/in...p=%2Fother_bulbs.htm
1. Scroll that page down to...PCB Series LED Lamps
2. Click the 1142 PCB tab
3. Click buy.
You are looking for this:
12VDC 1142 Base (dual contact, single intensity, no connection to metal base) with 1-1/2 inch square circuit board
With 9 High Power White LEDs Designed for overhead lighting in boats, campers, box trucks, etc.
With 120 Degree Beam Pattern, 120 lumens, Cool White LEDs
8~30VDC (8~14VAC)
Price for each.
Re: LED Lights 1 year, 4 months ago #1214
  • sbrock
  • OFFLINE
Thanks for the suggestion. I was able to find a LED light bulb that worked. I appreciate your response. Stephen
Re: LED Lights - Performance?? Pleased? 1 year, 3 months ago #1232
  • paulhelweg
  • OFFLINE
I read the IP Forum posts on the LED changeout and the details you have provided are very helpful; thank you.
Now can you comment as to your level of satisfaction with the LED light performance? Do the light "panels" remain in place ok as installed per your pictures with the adhesive tape? did you have to cut the plug in wires to shorter lengths or did it all fit in to the recess of the light fixtures behind the LED panels? I may give this one a try too this coming spring......thanks Paul Helweg/Wickford, RI
Re: LED Lights - Performance?? Pleased? 1 year, 3 months ago #1234
  • hayden
  • OFFLINE
  • Moderator
Paul:
The LED lights remain in place just fine, non have fallen out now in over 8 months since installed. As for satisfaction with light level, we are more than pleased! They are brighter then expected, they are warm, and not harsh, and now we have 10 lights on at night and do mnot even think about it. We have been living aboard now for 8 months with these and I wish I had done this sooner. They are expensive but well worth it. I have 2 more fixtures I can add into then all are complete. We did not have to cut any wires, we just installed them as described with double faced tape. I would highly recommend this addition.
Photos again are here:
ipyoa.com/photos/62-hayden/album?albumid...en/album?albumid=143
  • Page:
  • 1
  • 2
Moderators: shawnee, CapnBlaine
Time to create page: 0.26 seconds
