IP 35 Anchor Chain Ramp
13 years 10 months ago #1514 by hayden
IP 35 Anchor Chain Ramp was created by hayden
We originally had a vertical windlass, SL1000, and now we have a horizontal, Tigress Lofrans, and both of these have worked very well with our chain ramp to drop and deliver the anchor chain into the chain locker. On the IP35, this deep point of the chain locker is well aft of where the chain comes into the locker, so a ramp is needed. We added this ramp using starboard and a side guide to keep it on the ramp. The ramp measures: 30" long, 10" wide and it drops 15" from top to bottom. The ramp ends right over the deepest point.
Here are some photos of the ramp, NOTE: This is while on anchor with 100' deployed, so 100+ feet remain in this locker. We carry 250' 5/16" ht chain with about 40' of the end in the second locker bottom.
Overview of ramp
Drop of ramp with chain on ramp, this never backs up, and if it does, it will fall on its own.
13 years 10 months ago #1516 by rlwestlake
Replied by rlwestlake on topic Re: IP 35 Anchor Chain Ramp
Nice photos. I wanted a ramp and was not sure what slope would work. I didn't want to commit fully, so rather than epoxy supports, I filled in under the ramp with "sealed air" packing material to support it. My ramp is 6 x 30 starboard, and therefore lower, and less drop. It didn't work (castled and tumbled), and I haven't returned to the drawing board. Maybe I'll try wider, higher, and more drop as with yours. Thanks for the specs!
Rich W.
13 years 10 months ago #1518 by spinaker75
Replied by spinaker75 on topic Re: IP 35 Anchor Chain Ramp
My chain locker looks a little different than yours. I have a divider runs from just aft of the stay sail turnbuckle up to the deck. Might have been added by a previous owner. When you say it drops 15" is that over the 30" run or the aft end is 15" below the deck. Also couldn't tell for sure, is it tilted from starboard to port or level. Any idea on the angle. I used 20 degrees and it is apparently not enough.
Bob
13 years 10 months ago #1519 by hayden
Replied by hayden on topic Re: IP 35 Anchor Chain Ramp
Bob:
Yes, the 15" drop is over the length of the 30" board. I did not measure how far down from the deck it is.
Time to create page: 0.231 seconds
We have 1414 guests and no members online
