Powerpoint presentation
  • a Guest's Avatar Topic Author
15 years 4 months ago #653 by a Guest
Powerpoint presentation was created by a Guest
I am puting together a Powerpoint presentation for my sailing club and would like to add some charts. Is there a way to download them from the internet or must I take a photo and upload? Thanks Tom
15 years 4 months ago #654 by hayden
Replied by hayden on topic Re: Powerpoint presentation
On a PC you can use the print screen key, top right side, says prt scr, and this will load the clipboard with whatever you have on the screen. Then you can paste this screen into ppt. I use this all the time. If you want a better screen capture program, then look at jingproject.com and install that. This will allow you to capture any area of the screen and save it as a jpg. One more option is Windows 7 which comes with snagIt. This is another screen capture.
So, load up your charting program and capture your screens. If you need a free charting program, see the document in our doc library about SeaClear.
The following user(s) said Thank You: a Guest
15 years 3 months ago #670 by a Guest
Replied by a Guest on topic Re: Powerpoint presentation
Thanks for your help Hayden, I have loaded all the charts and downloaded SeaClear but I can not get the charts into it. The way I have had to get the charts into Powerpoint is to load SeaClear, go to charts and then go to "not listed" where I find the charts in the Downloads Desktop Tom ALL_RNCs BSB_ROOT. The path seems to be C:UsersTomDownloadsALL_RNCsBSB_ROOT but doesn't load into SeaClear. It also says the charts should be registered but where?
15 years 3 months ago #673 by hayden
Tom:
To get your SeaClear system set up with the FREE charts, please see this document I wrote in the document library. It will explain the entire process.
PDF version titled:
Set up SeaClear Free PC Nav add NOAA Raster Charts
ipyoa.com/docs/doc_download/61-set-up-se...d-noaa-raster-charts
MS WORD Version titled:
How to set up SeaClear Free PC Navigation with all NOAA Raster Charts ver2003
ipyoa.com/docs/doc_download/53-how-to-se...aster-charts-ver2003
These documents are under the CRUISING RESOURCES section of our document library:
ipyoa.com/docs/cat_view/90-cruising-resources
Let me know if you need more help, this SeaClear and loading charts is a bit tricky.
15 years 3 months ago #674 by a Guest
Problems with getting charts ito SeaClear
15 years 3 months ago #675 by hayden
Did the steps in my doc NOT work?
Time to create page: 0.120 seconds
We have 1615 guests and no members online
