PS to IP26 water tank
  • a Guest's Avatar Topic Author
14 years 8 months ago #1051 by a Guest
PS to IP26 water tank was created by a Guest
I see that the intended surveyors email attachment has not taken. I will if asked figure out how to convert to an acceptable format to attach.
14 years 8 months ago #1052 by hayden
Replied by hayden on topic Re: PS to IP26 water tank
David:
Attached files are fine. If you need help, please send the file to me and I will add this to your post.
My Name @ gmail.com
14 years 8 months ago #1055 by hayden
This is what I could get out of the attachment from the surveyor..
copy
Karsten Johnson,
IPY Customer Service
The vessel is an IP 26 MKII built in 1983. Scum lines and barnacle
growth (she was moored in a dirty harbor) indicate that she was resting
4-5" down at the stern. The cockpit lazarettes did not contain any
great amount of heavy gear except a water heater in the port lazarette
that weighs approx 80# (with water). Along with the plastic 31 gallon
water tank, the boat was also fitted with an aluminum 31 gallon tank
located in the bilge below the main cabin sole. Among the ship's papers =is an IP drawing #214A titled "Water System - Charter Spec." The water
from the standard plastic tank flows ("cascades") directly into the
aluminum bilge tank.
If the 31 gallons in the plastic tank were used up, could the remaining
31 gallons in the bilge tank (along with the water heater) set the stern =low? Was any ballast added up forward to compensate for this? Any
thoughts?
Regards,
Merrill Hall, SAMS-AMS (Ret.)
end copy
The following user(s) said Thank You: a Guest
14 years 8 months ago #1082 by a Guest
Replied by a Guest on topic Re: PS to IP26 water tank
Thanks Hayden for converting my failed attachment. Hope I get some responses.
Cheers
David
Time to create page: 0.100 seconds
We have 1717 guests and no members online
